Does OnShape CAM support part holding tabs?
Hello, I'm working on a CAM setup to perform a simple profile cut of a part on a CNC Router and would like to add part holding tabs to the outside cut profile. Is there a setting to enable these in OnShape easily or would some form of workaround be needed?
Thank you in advance for any pointers!
  • maggie_hyslop
    maggie_hyslop Member Posts: 2 ✭
    I would also like to know about this same thing - has there been any change on this?
