Is it possible to see the FS source code, for functions that are not documented?
dave_cowden
Posts: 484 ✭✭✭
When I encounter functions in FSDoc that have TODOs, I could help myself if I could see the source code or examples.
Are either available? When I am digging around and encounter these, i'm not really sure where to go next.
Examples: importForeign, ImportDerived, extrude, fillet.
Certainly: you have access to our entire feature library source code here: https://cad.onshape.com/documents/12312312345abcabcabcdeff
Our features can also serve as examples.
Once you open a Feature Studio, you can use the search functionality to navigate the library. Soon we will also have improved navigation tools.
So far we haven't documented all the features, but have documented corresponding operations (opExtrude, opFillet, etc.), which are the lower-level building blocks of features.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
So far we haven't documented all the features, but have documented corresponding operations (opExtrude, opFillet, etc.), which are the lower-level building blocks of features.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
Oh WOW! ok i just posted a Dome feature, and this would have helped things along quite a lot. I can live without docs if i have the source
maybe this is why i was having a hard time figuring out things others seemed to figure out
thanks!0
