Splitting a solid only part way through
benn_banks
Member Posts: 20 ✭
Im trying to plit the lower paddle off this part without slicing all the way up the part.
I tried splitting with a sketch but i cant select a sketch when splitting.
Whats the best way to remove just the lower portion without affecting anything higher on the part??
_Dave_
_Dave_ is actually correct, create a sketch defining the width of the slot and cut it to the desired depth.
Phillip is right that a planar surface will split infinitely, just like a construction plane.
To work around this, you can split with a surface that's only partially planar to get the behavior you want.
e.g.:
Note that this is valid because it still produces manifold topology (in this case two bodies).
The OP asked to make an infinitely thin slit - this is non-manifold topology (a valid solid may not have more than one face meeting an edge and no two faces may be coincident - there is a more technical definition, but this will do for now).
The original ask is for a non-manifold body and Onshape won't let you do this - moreover, its non manufacturable. i am not chastising anyone, this is just an interesting discussion. Any of the methods espoused here are valid.
If a surface is bounded, then why would it (attempt to) split anything outside it's bounds. This surface should not split the upper part of this solid, but it does:
You're right that the current behavior feels inconsistent. I believe it was a conscious UX decision, the reason being, once we start allowing people to split with faces, rather than just surfaces, a planar extension is the natural thing to do, e.g.:
The reason we don't extend non-planar surfaces is more a mathematical problem than a UX one
This specific case has been filed as a bug, since you're right that we don't have a good (i.e. discoverable) way of solving it, or other cases like it. As with all things in UX, the solution here will be a matter of balancing a number of different considerations, and the exact solution could be changing the defaults, or adding explicit options, or something else entirely.
