Drawing on a new plane but wanting to align a new sketch to elements on another plane
michael_fuller
Member Posts: 23 ✭✭
I've offset a new drawing plane, I can see existing geometry that resides on a different plane through this plane and want the sketch I'm creating on this new plane to align exactly with the existing geometry. In SW you could do this two ways, you could select elements of the existing geometry that is on that other plane and effectively recreate them on the new plane. Or you could essentially retrace it as SW knew to offer the option to snap to those elements as a reference when drawing new lines, etc., even though it was on a different plane. So, how do I do this?
_Dave_
1) By changing sketch plane
2) By using use command
3) By using copy and paste sketch option
Kindly refer below video for more detail.
