Global Variables
dan_dias
Member Posts: 2 ✭
My project has a few Part Studios. They use the same variables (at the least most of them overlap).
Is there a way to define a variable that works across multiple Part Studios?
For example:
I have a bunch of frames and panels in one Part Studio.
To make things easier, I created tubs that connect those frame together in a separate Part Studio.
A lot of the lengths and widths are the same.
I'm not sure I'm missing something or if this feature is not available. Help?
For example:
It's not available yet. And I think you can't derive variables as a workaround.0
