Creating acircular pattern in featureScript
wayne_jayes
Member Posts: 13 ✭✭
Would someone be kind enough to look at the script in this document
https://cad.onshape.com/documents/623b04759dbfa9159178fe48/w/3f75f7adc024168001e48971/e/ebff95d2dd43547b3b99a055
and point me in the right direction to fix the circularPattern. I am trying to make a flange for joining sections of pipe
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,258
The problem (as of 2:28 EST) was the ids -- you added the loop counter into the id on one of the features, but not the other ones in the loop. And the (currently harder to diagnose) other problem is that you added the counter after the string rather than before, which would cause breakage because if the id sequence is id+"cylinder3"+1, id+"transform1"+1,... id+"cylinder3"+2,... we have to "reopen" id+"cylinder3" after it's been closed. So the code for the loop body that works (also the queries need the loop counter in the id) is:fCylinder(context, id + i + "cylinder3", { "bottomCenter" : vector(0, 0, 0) * millimeter, "topCenter" : vector(0, 0, 1) * definition.THK, "radius" : 0.5 * definition.HoleDia }); opTransform(context, id + i + "transform1", { "bodies" : qCreatedBy(id + i + "cylinder3", EntityType.BODY), "transform" : transform(vector(cos(i*180*degree/definition.NumHoles), sin(i*180*degree/definition.NumHoles), 0) * definition.PCD/2) }); booleanBodies( context, id + i + "boolean2", { "tools" : qCreatedBy(id + i + "cylinder3", EntityType.BODY), "targets" : qCreatedBy(id + "cylinder1", EntityType.BODY), "operationType" : BooleanOperationType.SUBTRACTION });Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
mickael
Member Posts: 8 ✭✭
There is just a mistake in the transform vector (180 instead of 360 degrees)
annotation { "Feature Type Name" : "Flange" } export const myFlange = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type annotation { "Name" : "Outside Diameter" } isLength(definition.OD, LENGTH_BOUNDS); annotation { "Name" : "PCD" } isLength(definition.PCD, LENGTH_BOUNDS); annotation { "Name" : "Internal Diameter" } isLength(definition.ID, LENGTH_BOUNDS); annotation { "Name" : "Hole Diameter" } isLength(definition.HoleDia, LENGTH_BOUNDS); annotation { "Name" : "Flange Thickness" } isLength(definition.THK, LENGTH_BOUNDS); annotation { "Name" : "No of Holes" } isInteger(definition.NumHoles, POSITIVE_COUNT_BOUNDS); } { fCylinder(context, id + "cylinder1", { "bottomCenter" : vector(0, 0, 0) * millimeter, "topCenter" : vector(0, 0, 1) * definition.THK, "radius" : 0.5 * definition.OD }); fCylinder(context, id + "cylinder2", { "bottomCenter" : vector(0, 0, 0) * millimeter, "topCenter" : vector(0, 0, 1) * definition.THK, "radius" : 0.5 * definition.ID }); booleanBodies(context, id + "boolean1", { "tools" : qCreatedBy(id + "cylinder2", EntityType.BODY), "targets" : qCreatedBy(id + "cylinder1", EntityType.BODY), "operationType" : BooleanOperationType.SUBTRACTION }); for (var i = 0; i < definition.NumHoles; i += 1) { fCylinder(context, id + i + "cylinder3", { "bottomCenter" : vector(0, 0, 0) * millimeter, "topCenter" : vector(0, 0, 1) * definition.THK, "radius" : 0.5 * definition.HoleDia }); opTransform(context, id + i + "transform1", { "bodies" : qCreatedBy(id + i + "cylinder3", EntityType.BODY), "transform" : transform(vector(cos(i * 360 * degree / definition.NumHoles), sin(i * 360 * degree / definition.NumHoles), 0) * definition.PCD / 2) }); booleanBodies(context, id + i + "boolean2", { "tools" : qCreatedBy(id + i + "cylinder3", EntityType.BODY), "targets" : qCreatedBy(id + "cylinder1", EntityType.BODY), "operationType" : BooleanOperationType.SUBTRACTION }); } });And it works
1
For what you are trying to do, a circular pattern is one possibility, but it might be easier to just put your cylinder, transform, and boolean into a for loop.
