closed path not creating a face
Hi,
I have a simple sketch here https://cad.onshape.com/documents/e1f0909710ab2af754bfa7ce/w/ba81f66e21dfc5e618f0ee92/e/c23f9213da11e626f8ce015a 'Studio part 3' where a closed path doesn't generate a face for extrusion.
Points seems to be connected. I'm not sure to understand where the issue is.
Anyone with a similar issue ?
Thank you,
Pierre
Thank you,
Pierre
I tried and I can find the guilty point but I don't get how to fix it.
For example, I created another part in the same doc I shared the link to. There is is a simple spline with 2 offsets on both side, joined at their end.
The first path is closed and a face is created
The second path is a copy/paste of the first where I only move the end of the spline and the face is not created.
Any clue ?
