Set current view
david_banman
Member Posts: 3 ✭
in Inventor I had the option to set my current view as home view, if there was an option that I could set a face to any plane would be good.
example view normal to, and then select new front/top etc. view
Will named view in https://cad.onshape.com/help/#moving.htm?Highlight=named view solve your problem ?3
thanks it helps0
