featurescript: How to get a midpoint
I am trying to get a midpoint of a line
Here's the parameter:
        annotation { "Name" : "Lines", "Filter" : EntityType.EDGE && SketchObject.YES && GeometryType.LINE }
        definition.lines is Query;
And here's some code that I wrote.
        const lines = evaluateQuery(context, definition.lines);
        for (var line in lines) {
            var endpoints = qVertexAdjacent(line, EntityType.VERTEX);
            for (var epoint in endpoints ) {
                var point is Vector = worldToPlane(topPlane, evVertexPoint(context, { "vertex" : epoint }));
                var pvec = vector(point[0], point[1]);
                // Will use the point for various operations.
I want to get the midpoint of each line and use it to do an extrude.  Any idea how I might do this?  The code above is just a starting point (no pun intended).  The line with worldToPlane() is failing for me.
Disclaimer: I am a featurescript noob.
  • One easy way is with evEdgeTangentLine.
            var midpoint = evEdgeTangentLine(context, {
                    "edge" : line,
                    "parameter" : 0.5
            }).origin;
            debug(context, midpoint);
  • interesting and I might say weird.  But it works.
    Thanks!
    I also found that this works:
                var endpoints = evaluateQuery(context, qVertexAdjacent(line, EntityType.VERTEX));
                var A is Vector = evVertexPoint(context, { "vertex" : endpoints[0] });
                var B is Vector = evVertexPoint(context, { "vertex" : endpoints[1] });
                var midpoint = vector( (A[0] + B[0]) / 2, (A[1] + B[1]) / 2 );
  • ilya_baran
    edited June 2016
    @alan_1 in your method, your resulting midpoint vector is 2D (since you didn't add a third component).  An easier way of doing this that will give you a 3D vector is just:
    var midpoint = (A + B ) / 2;
  • ok.  I also tried doing a vector difference, but that's giving me negative units.  The result is then treated as having a different type than other vectors and I can no longer do arithmetic on them.  Here's my example:
                var normal = perpendicularVector(B - A) / norm(B - A);
                A += normal; // I get the error "Precondition of operator+ failed (lhs.unit == rhs.unit)"
    Here's the value of normal:
    Vector : [ ValueWithUnits : { "unit" : UnitSpec : { "meter" : -1 } , "value" : 6.273386374957768 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : -1 } , "value" : 8.171252121669061 } , ValueWithUnits : { "unit" : UnitSpec : { "meter" : -1 } , "value" : -0 } ]
    Note the '"meter" : -1'
  • I am not entirely sure what you mean by "get the midpoint and use it to do an extrude" -- perhaps if you post a manually modeled picture of what you want to accomplish in FS we could be more helpful.
    In terms of the units mismatch, here's how to think about it to understand what's going on:
    A and B are vectors with length units.  B - A is therefore also a vector with length units.
    perpendicularVector(A - B ) is a vector with no units and of length 1.  (I'm clarifying the documentation to state that explicitly)
    norm(B - A) has length units (it is the distance between A and B )
    If you divide a unitless vector by a length, you get a vector with units 1/length, hence the meters^-1 in your output.
    Perhaps you wanted to multiply by norm(A - B ) instead?  Also, perhaps you want to do evOwnerSketchPlane(context, { entity : line }).normal
    to get the normal of the line's sketch plane (rather than an arbitrary perpendicularVector).
  • That's very helpful Ilya.  Thanks!  I was misinterpreting the documentation of perpendicularVector() and the meaning of 'UnitSpec : { "meter" : -1 }'.  I had been hoping to get a vector in the line's sketch plane that is perpendicular to the vector A-B, but I still don't see an easy way to do that with the tools given.  I have been digging trying to find something appropriate.  Maybe using skConstraint() with "constraintType" : ConstraintType.PERPENDICULAR and with two lines: the original one discussed and one that goes through the midpoint.  The only problem is I don't know how to create a new point for the 2nd plane without specifying its location and thus defeating the skContstraint().  Maybe I'm just thinking about it wrong though.
    BTW, the documentation for skConstraint doesn't even mention "localFirst".  Doh!  I got lucky and found a reference to it in an example.  Who knows what other mystery parameters it might accept!?
    There's probably a way to project the perpendicular line onto the sketch plane I suppose.  skConstraint() seems to have something like this.
  • Here's some example code that will hopefully help:
    annotation { "Feature Type Name" : "Perpendicular" }
    export const perpendicular = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "My Query", "Filter" : EntityType.EDGE && SketchObject.YES, "MaxNumberOfPicks" : 1 }
            definition.line is Query;
            var sketchPlane is Plane = evOwnerSketchPlane(context, { "entity" : definition.line });
            var selectedLine is Line = evEdgeTangentLine(context, { "edge" : definition.line, "parameter" : 0.5 });
            var midpoint is Vector = selectedLine.origin; // Length units
            var perpendicular is Vector = cross(sketchPlane.normal, selectedLine.direction); // Unitless, normalized
            debug(context, line(midpoint, perpendicular));
  • Thanks again.  Problem solved!
