Creating a super elipses featurescript
Michael_Goldblatt
Michael_Goldblatt Member Posts: 3 ✭
Super elipses for reference: http://demonstrations.wolfram.com/VisualizingSuperellipses/
I'm trying to create a superelipses featurescript, but am having some trouble getting the shape to behave the way I want.
The two solutions I can think of are to 1) make geometry and then constrain it (so that the corner fillets are tangent to the rest of the arcs) in featurescript.
or 2) to make a sketch that will plot equations with a selected origin.
"The superellipse has parametric equations , ,
 for  in the first quadrant (, ); multiplying by  gives the equations for the curve in the other quadrants."
Any insight would be great.
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
    I think the best way is to make a sketch.  Calculate the points all around the superellipse explicitly and use a single skFitSpline call (or if the superellipse has four sharp corners, use four skFitSpline calls).  Let me know if that's enough to get you through or if more info is needed.
  • Michael_Goldblatt
    That is what I ended up trying to do. Actually stuck now on skfitspline. I get no errors but it won't create the geometry.
    This is what I have:
      skFitSpline(sketch, "spline", {
              "points" : [
                  point1,point2,point3,point4,point5,point6,point7,point8,point1
    Where the points are skPoint that I can see.
    Thanks
  • Michael_Goldblatt
    Woops just figured it out. My spline was crossing over itself.
  • ilya_baran
  • mahir
    mahir Member, Developers Posts: 1,324 ✭✭✭✭✭
    Very nice, Ilya. I did something similar in SW. I'm currently working on a more versatile parametric XYZ curve, but I'm having trouble getting FeatureScript to evaluate string expressions as values, e.g. "tan(45)" should evaluate to 1.
  • ilya_baran
    @mahir_abrahim
    Unfortunately I think having the feature user input the equation is very difficult to do for now, since we don't allow much even in the isAnything input and FS isn't great for string parsing.  We will need to do a bit of work on our side to make this possible...
