Planetary gear mates
stu_croysdale
Member Posts: 3 ✭
Hi there.
I have been playing with the onshape app on iPad, I've been modelling up a planetary gear (just for fun) but I'm struggling to get the gear mates to mesh or run correctly. I'm wondering if there is something I am missing.
Any tips very welcome.
Many thanks
Many thanks
Hi Stu,
I guess we need a bit more information. Can you share the doc or post some pictures of the setup? I guess you will need to- Create revolute mates for the parts that are turning
- Then constrain the revolutions with a gear constraint
1 -
On top of what @florian said, if the gears are not meshing after you've set the gear constraint. Go back and edit the revolute mates and rotate the secondary axis, this should be enough to get the right alignment for meshing. Let me know if this doesn't work.1
Here is a planetary gear system that our intern Ethan Rejto did that I made a copy of/modified a bit. It is a good example of how to mate together a planetary system.
https://cad.onshape.com/documents/578650ece4b02dc672b6313e/w/ce0a528bc931fb830cc89f7a/e/7ae73e028d75c0aaa7b99358
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com2 -
They are tricky. It all comes down to teeth number when getting it to mesh correctly. Follow these governing equations. And remember that the ratio you are calculating is the ratio of the input "the sun gear", to the output "the carrier". So set a gear ratio between the sun gear to the carrier. Follow these general equations.
Situation:
Ring Gear Stationary
Sun Gear Input
Carrier Output
Variables:
R = Number of Teeth on the Ring Gear
P = Number of Teeth on the Planet Gears
S = Number of Teeth on the Sun Gear
Governing Equations:
R = 2P + S
(R + S) / # of Planets = Even Number
Ratio = S/(R + S)
2 -
This might help you also, https://www.onshape.com/cad-blog/tech-tip-assembling-gears0
Hi Stu,
1 -
Hi guys.
Thanks very much for your comments.
@florian I'd got as far as setting all the mates and gear constraints but I think because I've already set mates for the sun and planet gears, trying to set a second mate with the planet gears to the ring gear is causing issues ??? I've tried to cheat it by making a gear constraint with the sun and ring gears (only because I thought it might be easier) but of course it still means applying two constraints to one gear.
@bradley_sauln , top tip about editing the revolute mates, I didn't know you could do that. I will let you know if this works for the meshing issue.
I will share the doc when I'm next working on it. I think my main problem is understanding if its possible to make planetary gears in onshape and if my theory of applying two mates to one gear is an issue.
Much apreciated
stu0 -
Situation:
Sun Gear Input
Carrier Output
Variables:
R = 2P + S
Ratio = S/(R + S)
2 -
This is brilliant ! Many thanks @jakeramsley for the model, very helpfull. Every thing I could possibly need is right there for me.
And @ethan, you spotted my error straight away. I had totally overlooked the fact that I should be creating the final gear ratio from the input to the out put. That is exactly where I've been going wrong. This is my first real go with any 3D CAD software and I guess a planetary gear set was a bit ambitious but it's prooved to be a great learning exersise so thanks again every body.
Best wishes
Stu
