How to inhibit precondition enums based on earlier entry.
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
Looking for some help regarding precondition enums, and specifically an elegant method of inhibiting some options depending on what is entered earlier.
Suppose we have one enum for drink type, and another for drink size
Further suppose Beer is only available in Medium and Large. (Who'd want a small beer anyway?)
How do we take away the option for the user to pick a small beer?
The least terrible idea I've come up with so far is to have multiple enums populated as to what's available:-
Is this plausible?
Is there a cleaner more elegant method?
I think what I'm really after is something along the lines of-
if definition.DrinkTypeChosen = Drink_Type.BEER then enum Drink_Size.Small.hidden = true
As ever, thanks for your help.
export enum Drink_Type
annotation { "Name" : "FizzyPop" }
POP,
annotation { "Name" : "Juice" }
JUICE,
annotation { "Name" : "Beer" }
BEER
export enum Drink_Size
annotation { "Name" : "Small" }
SMALL,
annotation { "Name" : "Medium" }
MEDIUM,
annotation { "Name" : "Large" }
LARGE
} annotation { "Name" : "Select Drink Type" }
definition.DrinkTypeChosen is Drink_Type;
annotation { "Name" : "Select Drink Size" }
definition.DrinkSizeChosen is Drink_Size;
export enum Drink_Size_Default
SMALL,
MEDIUM,
LARGE
} export enum Drink_Size_Beer
MEDIUM,
LARGE
} if (definition.DrinkTypeChosen == Drink_Type.BEER ))
definition.DrinkSizeChosen is Drink_Size_Beer;
else
definition.DrinkSizeChosen is Drink_Size_Default;
Is this plausible?
That's definitely plausible for simple situations.
I think the best way to get this behavior generally is to use a LookupTablePath as the annotation; also check the source for the hole feature. This does mean you have to define a table, but that could be automated with your choice of scripting language, and if you need a lot of customization it will definitely be better than defining many enums.
Arul Suresh
PhD, Mechanical Engineering, Stanford University6 -
You're right, we don't have a great way of doing this right now. @lemon1324 has it spot on: There's two decent options.
Option 1 is to do essentially what you've proposed, with multiple enums. One issue that will come up is that you'll have to name the parameter itself different things in the different cases (see the feature UI docs).
To consolidate your enums back to a variable of one type, at the beginning of your feature you'll also need to add logic to convert back e.g.definition.BeerSizeChosen != undefined) definition.DrinkSizeChosen =definition.BeerSizeChosen as Drink_Size_Defaultif (
Option 2 is using a LookupTablePath to create a full tree of options, all centered around one parameter (or set of params)
For example:const oz is ValueWithUnits = 29.5735 * centimeter ^ 3; export const sizeTable = { "name" : "region", "displayName" : "Region", "default" : "EU", "entries" : { "EU" : { "name" : "size", "displayName" : "Size", "default" : "medium", "entries" : { "small" : 8 * oz, "medium" : 12 * oz, "large" : 16 * oz } }, "US" : { "name" : "size", "displayName" : "Size", "default" : "large", "entries" : { "medium" : 16 * oz, "large" : 32 * oz, "supersize" : 64 * oz } } } }; annotation { "Feature Type Name" : "Soda" } export const soda = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Soda size", "Lookup Table" : sizeTable } definition.sizeTable is LookupTablePath; } { println(definition.sizeTable); var selectedRegion = definition.sizeTable.region; var selectedSize = definition.sizeTable.size; var size = sizeTable .entries[selectedRegion] .entries[selectedSize]; println(size); fCylinder(context, id + "cylinder1", { "topCenter" : vector(0, 0, 0) * inch, "bottomCenter" : vector(0, 0, 1) * size ^ (1/3), "radius" : size ^ (1/3) }); });We are looking into ways of solving problems like this better on a high level (where feature options control one another), so if you could share your specific case (publicly here, or privately by emailing kotoole@onshape.com), we'd love to hear about it!
7
Arul Suresh
7 -
Thanks Gents, excellent information.
The benefits of the table method seem to outweigh the minor inconvenience of setting them up.
I really appreciate you guys taking the time to explain the process.
@kevin_o_toole_1 This is for a "Nut Pocket" featurescript that I said I'd have a go at. (My first attempt at fs, so please don't expect much.) I'll make my first stab at the problem public later today.
Cheers,
HWM-Water Ltd0 -
@owen_sparksowen_sparks said:I'll make my first stab at the problem public later today.
Is the document public?
If so, what is the link I would use to get to it?0 -
@owen_sparks
I'd definitely use the heck out of a feature like this. Did you end up getting it to a point you were happy with?0 -
@Evan_ReeseEvan_Reese said:@owen_sparks
Sorry I became ill after posting this so real life got in the way. After getting better I'm afraid I didn't get around to picking it up again.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
The important thing is that you're ok! I might take a stab at something similar in the future. It's a good concept.owen_sparks said:
Owen S.0
