Gear meshing
andy_grove
Member Posts: 2 ✭
I've used the spur gear featurescript and I have an assembly now with my two gears (https://cad.onshape.com/documents/57ead699d91ac010bb7d276e/w/2d8983e55d976a19f40ab2ab/e/63d035b7c31f15bfa1154c95) and I can move the gears but they do not mesh properly.
If I suppress the gear relation I can move one of the gears to line them up correctly but when I unsuppress the gear relation it moved the gears back to how they were (misaligned).
I need to see if my gears will actually work "in real life" and can't figure out how to get past this. Any pointers would be appreciated!
In order to get them aligned properly, you need to adjust the actual mate connector for one of the gears.
Click on the little '>' icon next to the Revolute mate for one of the gears to see the actual mate connectors.
Then right-click on one of the mates and select "edit" to edit the rotation of the connector to what it needs to be.
Here is an example:
5
Here is an example:
5
