How do you hide/unhide the browser tabs and URL address
eric_taylor
Member Posts: 3 ✭
Going to full screen is great, but I haven't figured out how to hide the browser tabs and URL. It is consuming valuable screen space.
@eric_taylor, You can use below method to hide/unhide the browser tab and URL address.
1st Way:- If you create an Application Shortcut on your Desktop, it will remove all tabs, menus, etc, and give you a completely clean view.To do this:
- Click the menu, and go to “More Tools” → “Add to Desktop…”
- Make sure to check, “Open as window” (see screenshot)
This will create a shortcut on your desktop. When clicked, that shortcut will open as a clean window with no tabs, address bar, or menu options.
2nd Way:- The closest you can get is by using a keyboard shortcut to enter Full-screen Mode. You can press F11 on Windows, and Cmd+Shift+F on Mac.
Safari for the Mac has a View menu option to "Always Show Toolbar in Full Screen." Unselect that option and all browser chrome goes away. There are similar options for Chrome and Firefox if I recall correctly.0
