message output in FS
papawo
Member, Developers Posts: 206 PRO
can i pop up a message on screen in FS?
Yes, sort of. You can print to the notices area using functions like println (the debug function also outputs stuff there). You can also cause a blue bubble with a message to appear at the top of the screen when the feature is being edited using reportFeatureInfo (https://cad.onshape.com/FsDoc/library.html#reportFeatureInfo-Context-Id-string)Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
