Total 3D Newbie Question
larry_athey
Member Posts: 10 ✭
I will start off by saying that my only computer drawing/diagramming experience is in the 2D world using basic programs such as Dia and Gimp under Linux. So, it's safe to say that things in the 3D world are not obvious to me.
Now, I'm not looking for somebody to hold my hand, I'm just looking for examples that I can watch and then use that as a guide to get me where I need to be. What I need to 3D print is something very similar to a 4" PVC 45 degree Y coupler where the 45 degree connection is a 2" connection. That's just what it's similar too, going to a hardware store and just buying one isn't going to get me what I need.
I have watched a number of Onshape tutorials and I have yet to find one that shows something like joining two pipes together at a 45 degree angle. Go ahead and laugh, but all I've managed to figure out so far is how to make a 4" pipe that is 4" long and has 1/8" thick walls. How to join a 2" pipe of the same wall thickness to the side of it at a 45 degree angle and punch a hole through the side of the 4" pipe is totally escaping me.
Can anybody point me towards some tutorials showing me anything that would get me down the road?
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646Hi Larry,
I went ahead and made a simple mockup of what you wanted so you could see one approach to making it (by no means is this the right/only way).
https://cad.onshape.com/documents/0d5c6922517bbba54cec90a5/w/7c5e47c5000b33eb5c47ed2d/e/852a6d3044cd0abd5e63dd70
What I did was:- Made the original pipe by extruding the area between 4-inch and 4 1/8-inch sketch circles
- Added a "Offset" plane halfway up the pipe
- Drew a line tangent to the pipe on this plane
- Added a "Line Angle" plane using the tangent line and a 45 degree angle
- Sketched a 2-inch and a 2 1/8-inch circle on the 45 degree plane
- Extruded those circles into another pipe (using the "Add" option in the dialog so the two pipes would join into one part).
- Extruded the inner circle of the original 4 inch pipe using the "Remove" option in the dialog so that it would remove the excess pipe material created by the 2 inch extrude
- Extruded the inner circle of the 2 inch pipe using the "Remove" option in the dialog so that it would punch a hole in the side of the 4 inch pipe.
Jake Rosenfeld - Modeling Team7 -
OptionsArmindilo Member Posts: 31 ✭✭Like Jake_Rosenfeld said, there is no right way and there is no 'only way'. Just to show you, here is how I would approach this part:
https://cad.onshape.com/documents/f6fec9930959f5e092add16f/w/cd8884dce5ef97e6734a4977/e/651a8e3cd8465d8cbf73b4ef
1. Make the main 4" pipe using a revolve feature. (sketch is on the front plane)
2. Make the secondary 2" pipe using a revolve feature. Make sure your feature is set to 'Add' not 'New'. (sketch is on the front plane as well)
3. Use the shell, specify your wall thickness, and select areas you want to remain open - in this case select the 3 places where the pipes enter.
Each method has it's pros and cons, and there are probably a hundred other ways that you could do this. The approach you take will be largely determined by your experience, your 'design intent', and your personal preferences. Take a good look at these examples and get a thorough understanding of how each of them functions. Keep it up! And keep asking questions!
7 -
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646Nice design Armindilo! Definitely a lot less complex than my 45 degree planes.Jake Rosenfeld - Modeling Team5
What I did was:
Feel free to copy this document; I expect this isn't exactly what you want, but I think that if you use the rollback bar to look how it was made one step at a time and double click the features to see what kind of parameters I used you will have a good idea of how to make something similar for yourself.Onshape, Inc.
As before, there are multiple correct ways to do it: I would modify 'Sketch 1' to have a narrower section at the bottom. I've copied my original example here to demonstrate:
https://cad.onshape.com/documents/f6fec9930959f5e092add16f/w/cd8884dce5ef97e6734a4977/e/6ba02fc8205a4094e46ba226
Edit: updated URL.
https://cad.onshape.com/documents/5859790b51077710486a8f8b/w/716cb9afff0a0d9bead7f527/e/1192545ab01868826d3c1fee
Beside Part1 you created Part2 in the PartStudio. New parts get allways a new colour. You can use "Edit appearance" to change the color.
Or do you want only one part inside the PartStudio? Then you have to edit "Extrude5" and switch from "New" to "Add" and select Part1 as "Merge scope". But that will not work because there is a gap between the two parts. Error: "Boolean resulted in no geometry change. The parts either do not intersect or are totally contained."
