Error when calling opSplitPart, CANNOT_RESOLVE_ENTITIES
Lee_HeskethLee_Hesketh Member, Developers Posts: 148 ✭✭
Hello all, yet again I have another error, but in a different script this time. I am creating a script that splits a part into laminations, for use when creating counter tops out of many boards for example. I am using a for loop with the variable i to do this.
The user selects the face which they want the board length to be and an edge for the direction. Then they specify the number of boards they want. I then use the edge to get the width and divide that by the number of boards. Then I create a construction plane such that its origin is offset by the thickness of each board. I am doing this in the for loop, so on each iteration, the plane offsets another thickness each time.
Then the error... I am using opSplitPart() with the target as qOwnerBody(face) and the tool as the construction plane. However, I have an error of CANNOT_RESOLVE_ENTITIES. What am I doing wrong?
https://cad.onshape.com/documents/58d26491dbd4820fd5e392c8/v/d8e57c57dc9ea9c3ec23e7cf/e/3f67a0bdb932d66d53e4aa1c
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
    Thank you so much!
    Now, for some reason it only splits once. Any ideas?
    leon_pootleon_poot Member, Developers Posts: 87 ✭✭✭
    I was wondering the same thing. I found a trick: qSplitBy(featureId is Id, entityType, backBody is boolean), and then all you need to do is loop through the planes and newly-split bodies.
    So you'd end up with something like this inside your for-loop:
    var targets;
    if (i == 1)
        targets = qEntityFilter(qOwnerBody(face), EntityType.BODY);
    else
        targets = qSplitBy(id + ("splitPart" ~ (i - 1)), EntityType.BODY, false);
    var tool = qCreatedBy(id + ("plane" ~ i), EntityType.BODY);
    opSplitPart(context, id + ("splitPart" ~ i), {
                "targets" : targets,
                "tool" : tool
    Hope that helps.
    So what would the whole for loop look like?
    I am now getting a duplicate error
    Now it works for some reason. Thanks!
