Limiting decimal precision in print() with Regex
RootentityRootentity Member Posts: 21 ✭✭
I am working on making a simple CAM drilling feature script.
https://cad.onshape.com/documents/b571df08ddf1c4635358bf69/w/110a6ada5e5acec1cbc03228/e/fc6f2559c19db616bda0b63c
I need to limit decimal precision because many controllers, and some G code senders choke on long numbers.
I started by multiplying rounding and then dividing to trim the decimal places, but that didn't guarantee only four decimal places in every case. so now I am converting to strings and using a regular expression to trim the trailing digits off, however my expression is failing in some cases and I don't know why.
Here is the expression in question:
(-?\\d*\\.\\d{1,4}|^\\d$)
and Broken down:
-? = optional minus sign
d* = any number of digits
.d{1,4} = a decimal place followed by one to four digits
| ^d$ = or if it's not the previous format it's just a single digit
It's failing on numbers like 0.4 with a single digit a decimal and a single digit.  I am certainly no master at Regex, I can't figure out why it isn't caught by the first case?
Maybe I'm all off course and there is a simpler way to do this?
    I've solved this problem, I was using REGEX_NUMBER_CAPTURE to capture everything left over and this was causing the trouble. I've replaced the expression with this "([\\d-]+\\.\\d{1,4})\\d*?"  The \\d*? at the end accounts for all of the remaining digits after the needed four digits.
    Just did a bit more testing.  It is capturing one less digit than it should be up until there are five digits behind the decimal place.  If the number is 1.2 it fails, 1.23 captures 1.2, 1.234 captures 1.23, 1.23456 captures 1.2345, and 1.2345678910 captures 1.2345 as well.
