Query a line to use for value
Dylan_Stewart
Dylan_Stewart Member, Developers Posts: 107 PRO
I would like to be able to select a line and use the line's length to drive a variable all while being able to detect if there is a 90 degree corner or T and CROSS intersections.
What I am trying to accomplish is to be able to use a flat pattern and select either points or lines and produce models based on the location and length of the lines.
A bonus would be to import pre-modeled content that is variable driven.
Digital Engineering
