Need help with feature naming template
darren_13darren_13 Member, Developers Posts: 120 PRO
Hi, I am struggling with the feature naming template and have already checked most posts currently on the forums but from what I can tell my example should work:
feature definition:
annotation { "Feature Type Name" : "Profile Generator", "Manipulator Change Function" : "flipManipulators", "Feature Name Template" : "Aerofoil = #name", "Editing Logic Function" : "old"}
in main body:
setFeatureComputedParameter(context, id, {
                    "name" : "name",
                    "value" : 5
this gives a feature name of: Aerofoil = ?
If this isn't enough I can post a link but its
I changed the value to numerical because I read somewhere that it doesn't like strings? and also from checking the variable feature script what is the difference between ### and # used for ###name and #value
    edited September 2017
    I noticed that changing feature name template doesn't affect the name of prevously added features, try
    "value": " "~5
    or even set a whole string to value
    "value": "Aerofoil "~5
    and
    "Feature Name Template" : "#name"
    and add a new feature
    @darren_13
    I would expect that code to work. Can you post an example of a failing document? @konstantin_shiriazdanov is right that templates are fixed at the time of feature creation, we do not retroactively change existing features' templates, so you will need to create a new feature to test.
    On the "###" question, Onshape allows escaping "#" as "##", so the template "###name" will display a "#" literal then the computed name.
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    Hi @kevin_o_toole_1, here is the link:
    https://cad.onshape.com/documents/95877be3b17f49277e87a2c3/w/b503830fd20472014beb1221/e/6a7730b786a3030938febbe7
    under profile generator (new) and the main script. I moved it up to line 266.
    I was creating new features to test, so that shouldn't be the issue.
    @konstantin_shiriazdanovcheers ill try that now.
    Hey Darren,
    I believe your issue is that something within the feature is failing, which causes the whole feature to be aborted, reverting any effect the feature had (including setFeatureComputedValue).
    Perhaps seeing a question mark only in the case the feature fails is fine for you. If not, the only computed values which are always set (even when the feature is aborted) are the parameters on the definition. So one option is to make an ALWAYS_HIDDEN parameter on the definition which is set via editing logic. Check out variable.fs for an example of this!
    Hi @kevin_o_toole_1, nothing is failing on it... I put a warning on it so myself and others know that they are test scripts. I have now removed it and nothing errors or warns. I did try that logic function method but got the same result. Can you open the new version and confirm that nothing fails and therefor the '?' should be populated? I'm using part studio 8 for testing.
    Thanks for your help,
    Darren
    maybe it don't like when "name":"name", try "name":"nameTemplate"
    Cheers @konstantin_shiriazdanov, I changed it to 'name' to simplify the problem. In doing this when I fixed it (without realising). it didnt display because of the 'name' being identical to 'name', in short, your above reply fixed my issue so thanks very much!
    Kind regards,
    Darren
