Infill a sketch face with choice of vertical or horizontal lines
Dylan_Stewart
Member, Developers Posts: 107 PRO
I'm creating a feature that will allow the user to query a face entity and the FS will fill in the sketch bounds with either vertical or horizontal lines.
I've been looking at the HexInFill feature, but I feel that it is much more complicated than what I'm trying to do.
Eventually, for each line the FS creates, I'll add a profile that extrudes along those lines with a border in the shape of the sketch (if that makes sense).
So, anyone care to take a jab at it?
I've created a public document that has an example (w/o FS) to show the intended purpose.
https://cad.onshape.com/documents/cb1ec1022d600cc62ed00546/w/c8ca520a1a8d35c80d26600d/e/4cdccdcfad5157f0b83a223c
Thank you!
Thank you!
Digital Engineering
i think features like infill some area by some pattern better to create using operations with solids. you fill the rectangular area of the sketch on the face by lines, extrude them like surfaces, thicken them, then perform boolean remoove, or any other operation you need with solids in 3d/
1 -
Do you have an example of this? Perhaps I am over complicating it.Digital Engineering0
not really an example, but a plan:
- query a planar face of the solid body
- evaluate 3d box of the face using evBox3d
- create sketch on the face
- evaluate start and end limits of the sketch lines using worldToPlane to the minCorner and maxCorner of the box3d
- create a number of lines in the loop from minCorner to maxCorner in the sketch
- solve the sketch and extrude the lines using qCreatedBy( ..., EntityType.EDGE)
- thicken extruded surfaces to solids
- delete extruded surfaces using opDeleteBodies
- delete sketch lines
- make some boolean with those solids and the original body obtained from qOwnerBody
