How to I evaluate a query and store one of the resulting entities?
tim268tim268 Member, Developers Posts: 3 PRO
edited October 2017 in FeatureScript
Hello,
I am hoping you can help me.
I would like to find the 2 largest Cylindrical surfaces on a part by surface area.
I can do this, but I think there must be a better method? I am used to object oriented programming in java where I could store this sort of thing using an object.
I havn't put the full code (as it long and may confuse things) but the basic method I am using at the moment:
// Query the all cylindrical faces
var cyls = qGeometry(qOwnedByBody(part, EntityType.FACE), GeometryType.CYLINDER);
var counter = 0;
var cylOneIndex = 0;
var cylTwoIndex = 0;
// Loop through the cylindrical faces
for (var cyl in evaluateQuery(context, cyls))
                var cylArea = evArea(context, {
                        "entities" : cyl
                // If the surface is largest by area - store it's array position/index
                cylOneIndex = counter;
                // If the surface is second largest by area  - store it's array position/index
                cylTwoIndex = counter;
counter += 1;
Then, if I want to use either of the 2 largest surfaces later on, I use Query Nth element (because I now know the  position/index):
qNthElement(cyls, cylOneIndex);
or
qNthElement(cyls, cylTwoIndex);
Is there a better way of doing this? Is it possible to evaluate a query and store one of the resulting entities? For example:
// Initialise the Cylinders as undefined??
var cylOne is Cylinder = undefined;
var cylTwo is Cylinder = undefined;
                        "entities" : cyl
                // If the surface is largest by area - store the Cylinder
                cylOne = cyl;
                // If the surface is second largest by area  - store the Cylinder
                cylTwo = cyl;
Then, if I want to use either of the 2 largest surfaces later on, I just used the cylOne or cylTwo variables? For example:
cylOne.radius;
or
cylTwo.radius;
My concerns with my current method are:
  • I am evaluating the query twice. I assume this is poor on performance?
  • What if the index/position of the entities changes in the array?
  • There must be a better way of doing this?
Any help would be appreciated! Thank you
Tim
    after you got the query of cylindrical faces by
    i would reccomend to make a list of map structures for each face like {"query": cylFaceQuery,"area":cylFaceArea}
    and sort that list with sort() function. the compare function should be: function(cyl1, cyl2) {return cyl2.area-cyl1.area}
    the two first elements of resulting list will contain the query and the area of two largest by area cylinders
  • tim268tim268 Member, Developers Posts: 3 PRO
    Hello Konstantin,
    Thank you for your quick response.
    Would you be able to explain how I make a list of map structures?
    Do I define an empty var? Loop through and add the maps to the var?
    //Define Empty var?
    var cylList;
                            "entities" : cyl
                    // Add a map to the array??
                    cylList + {"query": cyl,"area":cylArea};
    sort(cylList ,function(cyl1, cyl2) {return cyl2.area-cyl1.area;});
    I will try and work this out. But again any help would be appreciated. Thank you!
    Tim
    edited October 2017
    something like this - define an empty list and append it with newly calculated values in the loop
    var cylList=[];
                    var cylArea = evArea(context, { "entities" : cyl });
                    cylList = append(cylList, {"query": cyl,"area":cylArea});
    Got it!
    Thank you so much. I couldn't work out how to init an empty array and then append to it!
    I've been trying:
    var cylList = null;
    var cylList = undefined;
    var cylList[5];
    etc. etc.
    And:
    cylList[counter] = {"query": cyl,"area":cylArea};
    cylList += {"query": cyl,"area":cylArea};
    cylList.set(counter) = {"query": cyl,"area":cylArea};
    etc. etc.
    Seems stupid when you know  how!
    Thank you very much.
    Tim
    yep, featurescript doesn't pamper us by too big amount of syntax sugar :) so if you going to perform some standart operation to data structure you should likely search a function for this in its standart library
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,254 image
    There are qLargest and qSmallest queries that you can use for this.  To get the second largest face, you can do something like:
    var largestQuery = qLargest(faces);
    var secondLargest = qLargest(qSubtraction(faces, largestQuery));
