Multiple Mates
bill_wood
Member Posts: 12 ✭✭
Trying to understand 'pin mate'. I have the slider figured out, and the revolute, but i can't add the cam slot on this drawing. What am I missing?
https://cad.onshape.com/documents/e0b2edcc0e5c3e7535d0b93f/w/2658e74c0c76ebb728842000/e/a9db1da4fe07af4e20e85820
I believe the Pin Slot mate only really works for linear slots. What you need is a Tangent mate. If you want to center the pin in the slot you'll need to use an offset construction surface that is the width of your pin.
https://cad.onshape.com/documents/d0b98b9a11f06a52c1aba2fe/w/57efd147dff467c8df296d1b/e/04a0ac843ab1bbd9d15bd260
2
2 -
Prego
