Tangent edges of FeatureScript Beam can't be hidden on drawing.
Bram
Member Posts: 2 ✭
Hi,
I got square beam sections with rounded edges in my model. It seems as if the tangent edges of the beams don't respond to "hide tangent edges" as other direct modeled parts.
Gaby Rochino from support told me to tag @NeilCooke may be he can look into it?
This is the model i'm working on
https://cad.onshape.com/documents/5312821137b69db09c2e912b/w/bff976d1d778d55b2e4bcbe4/e/f404384693047f7b6b05014c
@Bram - the edges that hide belong to an extrude from a sketch - the sketch uses a sketch fillet which is naturally tangent. Your beam features are using your own custom profiles (using the standard profiles works with hidden tangent lines in drawings). My guess is that there is a rounding error in your profiles. Having taken a quick look, your millimeter profile is set to 4 decimal places, not 3 which is the correct DP for mm profiles. See if you can change your profile definition.Senior Director, Technical Services, EMEA1
Thanks @NeilCooke I'll take a look!
I haven't made any special changes to the decimal places? Any idea how this got altered? I'll let you know the outcome.0
