Using a for loop for multiple operations on multiple parts
Lee_Hesketh
Member, Developers Posts: 148 ✭✭
Hello, I have a script that makes a new sketch on a selected face, draw a rectangle, extrude and finally a Boolean subtraction. Currently it only works for one face at a time. How could I use a for loop to allow the operations to be done on all selected faces? This is for a mortise and tenon script I'm writing and when I tried to use a for loop an error was thrown concerning multiple operations with duplicate id names.
Any ideas?
Thanks
Lee Hesketh
Any ideas?
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
owen_sparks Member, Developers Posts: 2,660 PROHi, there's a good explanation in the help files somewhere for this. I'm sure someone will be along with a full explanation soon but the solution is to append i to the feature ID within the loop to make each iteration unique.
HWM-Water Ltd5 -
cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 213As @owen_sparks mentioned each feature/sketch needs to have a unique Id. An easy way to do this is to add "i" to you feature/sketch Id. Something similar to this...
<br>var sketchId = id + "sketch"; for (var i = 0; i < numberOfThings; i += 1) { sketchId = sketchId + i; var sketch = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane }); //sketch some stuff here }
Notice "i" is incremented with each pass of the for loop so the "i + 1" you mentioned is not needed.5 -
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646@Lee_Hesketh
Your skRectange is failing because the second argument is not supposed to be an id, its just a string that uniquely identifies this part of the sketch. This is true in general for all "sk" operations. Sketch code should look something like:const sketchId = id + "sketch"; var sketch = newSketchOnPlane(context, sketchId, {...}); skRectangle(sketch, "rectangle1", {...}); skRectangle(sketch, "rectangle2", {...}); skLineSegment(sketch, "lineSegment", {...}); skSolve(sketch);
Hope this helps,
JakeJake Rosenfeld - Modeling Team5
if I was using two extrudes, would the second one be opExtrude(context, id + "extrude" + i+1)?
https://cad.onshape.com/documents/57aee7f1e4b083f3982e60a4/w/720337d038a4a9744878f874/e/2059dc0192a94404a962ca5c
I copied your Doc and was able to get "Mortise and Tenon Test" feature to work, so I cannot recreate the error. I would debug your inputs for the rectangle and make sure they are correct. My guess is one of your variables should be a string, but is instead an array. Or something similar.
P.S. I found that using hash functions(see e.g. https://math.stackexchange.com/questions/531906/calculate-unique-integer-representing-a-pair-of-integers ), such as Cantor pairing function: id + 0.5*(i+j)*(i+j+1)+j works for low values of i, j, but then it becomes non-monotonic and the error "Parent Id FWDxIioBKfXZcAh_3.6 used at two non-contiguous points in operation history (Cannot have FWDxIioBKfXZcAh_3.10.2 between FWDxIioBKfXZcAh_3.6.1 and FWDxIioBKfXZcAh_3.6.0)" is thrown.
a pair of i, j is unique inside the loop so the id should be something like id + ("sketch" ~ i ~ j). "~" is a string concatenation operator
Hope this helps,
Jake
@ivan_skachko @konstantin_shiriazdanov
Note that if there is a large loop with konstantin's solution, you could run into a bad situation where the ids are not unique. For example:
i = 1 j = 12
"sketch112"
i = 11 j = 2
"sketch112"
This can be mitigated with something like:
"sketch.1.12"
"sketch.12.1"
or even:
Note that code like:
will fail because of id hierarchy.
From the documentation (https://cad.onshape.com/FsDoc/library.html):
