How to dimension a drawing of part made from a inscribed polygon
rachel_arden
Member Posts: 14 ✭✭
I've made a part based off the inscribed polygon sketch tool.
I now want to make a drawing of the part but cannot find a way to mark the circle the polygon is dimensioned off, is there a way to do this?
John_P_Desilets
Onshape Employees, csevp Posts: 262
rachel_arden
I have a work around that you can use to have a center mark on the polygon. From the parts studio, I extruded the circle used for the polygon as a surface and thickened the surface to .001mm. Next, I inserted both parts into the drawing. This allows me to create a center mark for the polygon.
https://cad.onshape.com/documents/d13ab483cf6299675237ffad/w/10cf12f79c73e27241e2c5a0/e/07742c4601758f07abab2f93
We are working on having the ability to create views of singular sketches and the ability to show sketched is a view. Please feel free to submit an improvement request.5
https://cad.onshape.com/documents/0aa40800cd63f8ebf857817b/w/7673badb56f6f93ed6ee1633/e/4a6e8d71cdb74ec3ca739c90
I was hoping not to have change the model. If Onshape is already working on it though then I'm happy, I'll do as you suggest and submit an IR to add my support.
