Linear pattern in sheet metal?
claus_jeppesen817
Member Posts: 39 PRO
When are you able to pattern features (holes) in 2 directions in sheet metal. I know you can use sketch pattern but that is not an option
1
lana
Onshape Employees Posts: 763
@claus_jeppesen817
We are working on an ability to pattern holes in active sheet metal as face pattern. I hope when this capability is released your use case will be satisfied. If your use case requires feature pattern, please write an Improvement request explaining your use case. Thank you.5
