Modeling a Square Tube in different ways to lear featurescript
emerson_bottero
Member, Developers Posts: 37 ✭✭
I think is the best when you can get something done in more than one way and feature script allows that. I don't mean to find the easy way, I want to learn from it.
1 - Create 2 square sketchs, Extrude both, remove the smaller from the biggest with Boolean. That one was easy!
--> Create 2 Sketchs
2 - Create 2 square sketchs, extrude the region in between. Couldn't query this region
3 - Create a sketch, extrude as surface, Thicken the surfaces. Couldn't Extrude as surface
--> Create a Sketch
extrude(context, id + "extrude1", {
Can Someone show how to make options 2 and 3 possible?
skRegularPolygon(sketch1, "polygon1", {
"center" : vector(0, 0) * inch,
"firstVertex" : vector(1/2,1/2) * mysize,
"sides" : 4
skRegularPolygon(sketch2, "polygon2", {
"firstVertex" : vector(1/2,1/2) * (mysize - mythick),
"sides" : 4
--> Extrude Both
--> Extrude Both
"entities" : qSketchRegion(id + "sketch1"),
"endBound" : BoundingType.BLIND,
"depth" : definition.myLength
extrude(context, id + "extrude2", {
"entities" : qSketchRegion(id + "sketch2"),
--> Booleans
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(id + "extrude2", EntityType.BODY),
"targets" : qCreatedBy(id + "extrude1", EntityType.BODY),
"operationType" : BooleanOperationType.SUBTRACTION
opDeleteBodies(context, id + "delete1", {
"entities" : qCreatedBy(id + "sketch1", EntityType.BODY)
opDeleteBodies(context, id + "delete2", {
"entities" : qCreatedBy(id + "sketch2", EntityType.BODY)
--> Create a Sketch
"sides" : 4
--> Extrude as Surface gives me this ERROR "throw EXTRUDE_NO_DIRECTION" |
"bodyType": ToolBodyType.SURFACE,
"surfaceEntities" : qCreatedBy(id + "sketch1"),
//"direction" : evOwnerSketchPlane(context, {"entity" : qSketchRegion(id + "sketch1")}).normal,
"depth" : definition.myLength,
--> Thicken the surfaces (couldn't test)
opThicken(context, id + "thicken1", {
"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
"thickness1" : 0.1 * inch,
"thickness2" : 0.1 * inch
2. - put both squares into the same sketch, pass "entities" : qSketchRegion (id + "sketch1", true) to extrude - that would filter out the inner region.
3. - pass "surfaceEntities" : qCreatedBy(id + "sketch1", EntityType.EDGE) , no need for "entities" field to extrude.
We recommend using opExtrude in feature script instead of extrude for better performance.2 -
Ok. First 15 min to respond !
. You Rock.
2 - you nail it. I'm using opExtrude.
3 - using extrude because didn't found BodyType option in opExtrude.extrude(context, id + "extrude1", { "bodyType": ToolBodyType.SURFACE, "surfaceEntities" : qCreatedBy(id + "sketch1", EntityType.EDGE), "endBound" : BoundingType.BLIND, "depth" : definition.myLength });
Didn't work and I could'n find why, I still get EXTRUDE_INVALID_ENTITIES. But
extrude(context, id + "extrude1", { "bodyType": ToolBodyType.SURFACE, "surfaceEntities" : qCreatedBy(id + "sketch1", EntityType.FACE), "endBound" : BoundingType.BLIND, "depth" : definition.myLength });Worked but it forms an SOLID, not SURFACE Body, I debug the query and both are working.1 -
@emerson_bottero
opExtrude doesn't need BodyType option. If you pass it edges in the "entities" field, it will make surfaces:
https://cad.onshape.com/FsDoc/library.html#opExtrude-Context-Id-map
If you post the URL of your document here, we'll be happy to take a look at why that extrude() is failing.Jake Rosenfeld - Modeling Team0 -
@Jake_Rosenfeld
here it is.
https://cad.onshape.com/documents/04194902b685ea2fdd1ea39e/w/d56fefaa6afcbf2753009eeb/e/4fc1173c8bd6628cd5713f2e
I did what I never saw in the documentation but I use ons sub-node of the LookupTable as valuewithunits, works as long as the entry has units in it.
Hi @emerson_bottero
You have it pinned down when you ask "Shouldn't this be 4 edges, not 8?" Due to the way our sketching system works, there are actually two sets of edges created when you sketch: the wire bodies that you directly create in your sketching operations, and the edges around the sketch regions that you create indirectly.
Long story short, the query that you want is:
qOwnedByBody(qBodyType(qCreatedBy(id + "sketch1", EntityType.BODY), BodyType.WIRE), EntityType.EDGE);
a.k.a. "All the edges of wire bodies created by the sketch operation"Jake Rosenfeld - Modeling Team0 -
thanks @Jake_Rosenfeld That's really complicated. Can I create a function or my on query for reuse in the rest of the code?
edit1: I did this and it worked.<div>function QSketchEdges(id is Id)</div><div>{</div><div> return qOwnedByBody(qBodyType(qCreatedBy(id, EntityType.BODY), BodyType.WIRE), EntityType.EDGE);</div><div>}</div>
and used like that.<br><div>opExtrude(context, id + "extrude1", { </div><div> "entities" : QSketchEdges(id + "sketch1"),</div><div> "direction" : evOwnerSketchPlane(context, {"entity" : qSketchRegion(id + "sketch1")}).normal,</div><div> "endBound" : BoundingType.BLIND,</div><div> "endDepth" : definition.myLength </div><div> });</div><p></p>0 -
@emerson_bottero
A correction from my coworker: qBodyType actually happily filters entities based on the body type of their owner, so a simpler Query is:qBodyType(qCreatedBy(id + "sketch1", EntityType.EDGE), BodyType.WIRE);
Nice function!Jake Rosenfeld - Modeling Team0
