Using coincident constraint
jose_popoca
Member Posts: 6 ✭
Depress the coincident constraint, select one circle then the other. The second circle is 3 times larger then the first. Question; Why does the second circle selected disappear?
Additionally, placed various entities, various size lines, circle, arcs... on first sketch, used the dimension tool on a circle, when hitting enter all the entities shifted outward, like an explosion. Why? Guess, really need to learn everything about dimensions vs constraints. At this point of question in learning due to stuck at a boolean usage. You know, back tracking to find what went wrong. Thanks in advance for help.
Right click on the circle and use "select other" and you should have two items in the list representing one of each of your circles. I would suggest to delete one and try again
Play around with some circles and the "coincident", "concentric", "equal", and "tangent" constraints so you can understand their behavior and you can understand whats happening and why. Be aware that circles can be constrained by their center and their edge.
The first dimension you place in a sketch scales the whole sketch. I.e. the line is ~3cm and you place the dimension and choose 6cm. The whole sketch will scale itself by 2 based on that first dimension placed.
Have completed many Onshape tutorial videos in sequence. Working on the Cantilever arm currently. Made it up to the usage of the boolean feature. Unable to complete this feature successfully lead to evaluating all steps to the beginning of the first part of the cantilever arm exercise. So created a new document, placed various size lines (solid and construction ), circles, arcs. Leaning to manipulate each move, size. The arc is the only one that can't be moved...
Maybe using/access a different sequence of videos?
Thanks for the video link!
Well, thanks for your time.
Have you figured out your issue or learned more about how constraints behave? Anything you need help with?
I expect the second circle looks like it has disappeared because it is on top of the other one. If you had first dimensioned both circles to different sizes before adding the coincident constraint the sketch will complain because it can't simultaneously make them different sizes and coincident. Or if you make two arcs coincident you will more clearly see that the radius and center of both arcs are the same but you still have two arcs.
What were you trying to do when making the circles coincident? Did you want them coincident at a point? There's a tangent constraint which will make two circles touch.
TVP, Onshape R&D
