Feature Script: How to set the "oppositeDirection"-Tag for extrude?
Hey!
I'm starting with feature script and work on a small script that simply needs a thoughhole. I ask the user for a point (around which I draw a circle) and a face to which the hole is going to. This part of the script looks like this:
        annotation { "Name" : "Vertex for center", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 1 }
        definition.center is Query;
        annotation { "Name" : "Back Face", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.backface is Query;
        var location = evVertexPoint(context, { "vertex" : definition.center });
        var sketchPlane = evOwnerSketchPlane(context, { "entity" : definition.center });
        const frontSketch = newSketchOnPlane(context, id + "frontSketch", { "sketchPlane" : sketchPlane });
        const center = worldToPlane(sketchPlane, location);
        // create the outer diameter circle
        skCircle(frontSketch, "throughhole_circle", { "center" : center, "radius" : radius });
        skSolve(frontSketch);
        extrude(context, id + "extrude1", {
                    "entities" : qSketchRegion(id + "frontSketch", true),
                    "direction" : sketchPlane.normal,
                    "oppositeDirection" : XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                    "operationType" : NewBodyOperationType.REMOVE,
                    "defaultScope" : true,
                    "endBound" : BoundingType.UP_TO_SURFACE,
                    "endBoundEntityFace" : definition.backface
I don't understand yet how to set the oppositeDirection-flag. To test the function, I created a sketch with two rectangles on the top-plane and extruded both in different direction. (negative and positive z-space). But only one generates correctly.
So how is the normal of a plane defined? And how can I just create a hole? There should be an easy way to say "Remove into the object", but I haven't found it yet.
    edited February 2018
    generally when you select sketch region on the face or the face of solid body itself the normal of the sketch plane is directed from the solid to outside. if you need to change this behavior you need to add new boolean parameter to the precondition of the feature (optionally with corresponding UIHint parameter) like that:
    annotation { "Name" : "Opposite direction", "UIHint" : "OPPOSITE_DIRECTION" }
            definition.flipDir is boolean;
    and then inside the feature explicitly flip extrude direction like that (or using if operator)
    extrudeDir = evSketchOwnerPlane(query).normal;<br>extrudeDir = definition.flipDir? -extrudeDir: extrudeDir;
    nikolas_engelhardnikolas_engelhard Member Posts: 5
    But if the normal of my sketch points to the outside, why does the extrude not always work?
    it hard to say something without having real feature
    This is already the complete script (without the autogenerated part). Which part are you missing?.
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,176
    @nikolas_engelhard The way to make it easy for people to help you is to actually post a link to the public document -- that way others can see the full source code in the feature studio and see how the feature is intended to be used in the part studio.
