functions question
papawo
Member, Developers Posts: 206 PRO
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646The body of your function does not use the 'context' variable, so there is no point to passing it in. I totally garbled the code block up there though, sorry. The call to the function should actually look like:
const getTRY = getInputFaces(definition.features);
Jake Rosenfeld - Modeling Team5
Your function isn't returning anything, which is why 'getTRY' also isn't anything. You'll need to actually return the Query:
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/return
EDIT: fixed code block.
why context is not use?
I've learned something today.
Thanks again!
