Pattern a Split or Alternatives
Paul_ArdenPaul_Arden Member, Onshape Employees, Developers Posts: 228 image
So, I have a part I want to split (and I explicitly want multiple parts, not a surface split). However I want to split it into a lot of segments, the only way I found to do it was to pattern the thing I am splitting with (in this case a plane) then create a whole lot of individual splits, like this:
This is obviously pretty painful, in this case setting up 21 splits. The first thing I tried to do was pattern the split feature however this does not work. The face split allows multiple entities for splitting but the part split only allows a single one.
Is there an obvious way to achieve this that I am missing? Note that I specifically want to start with the completed model and split it in this case, I am not trying to find a way to model it already split up.
