Merging surfaces
mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
I have a FS that deletes some faces from a solid and then fills in the open edges with opFill. Unfortunately, I don't see a Merge with all option for opFill. Now how do I recreate the solid part.I tried using Enclose, but I'm having trouble querying for the hollow surface body. qCreatedBy doesn't seem to do the trick. Little help?
https://cad.onshape.com/documents/833dffabd805010ce935bee2/w/d15b586cc7aa564eee76cc28/e/e06b1747a4949c3641434da2
    edited April 2018
    it seems like turning solid body to surface by deleting face still keeps body "id" just changing the body type. what if to try query resulting sheet body with the query corresponding to the initial solid?
    Edit:
    the way described above doesn't work, nor I was able to get created sheet body by subtracting queries for all surfaces after and before deleteFace was applied.
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    Thanks, @Jake_Rosenfeld. Using fill did the trick. I generally avoid using the UI version of functions, but in this case it seemed to be the most robust path - finicky creatures those transient queries.
    @mahir
    Definitely finicky.  A useful way of getting around them (if you need to) is to create a robust query like this:
    const transQ = qUnion(evalauteQuery(context, something));
    const robustQ = qUnion([transQ, startTracking(context, transQ)]);
    The union is needed in the second part because tracking queries do not evaluate to their original geometry, so we're unioning together the original geometry with any future geometry.  In this way, whether the transient id changes or stays the same, the query will evaluate to what you expect.  YMMV, but if you ever use this and it doesn't behave as expected, we're here to help.
    In most cases (including this one) the `op` functions do provide a more convenient programmatic interface.  The tradeoff is that the full feature may do a lot more than any one underlying operation, so sometimes it's worth it to wrangle an odd set of parameters to get the robust functionality.  Some other cases of this are patterns, mirrors, and any time you want to interact with Sheet Metal.
