Need help creating a smooth surface between intersecting lofts
sanford_morton
Member Posts: 6 EDU
Dear onshape community,
I have two lofts originating from different surfaces but converging on the same end surface. When they converge the concavity of the two lofts results in some overhang. Could you guys please recommend a way to remove this overhang? Open to all types of solutions. Splitting + deleting works for only one side of the overhang. Using offset surfaces to split seems to also be failing for me...
You should be able to edit / look at this document: https://cad.onshape.com/documents/c1e0e515587188ac6ec30327/w/7c6494d734d8b99b268a1728/e/954d00d8f44f6fcbcad99a8a
@sanford_morton - your request is very similar to this thread - please let me know if you have any questions.
https://forum.onshape.com/discussion/comment/38775
Philip Thomas - Onshape0
