Why do I get a "Duplicate feature parameter" error when defining parameters inside IF...ELSE?
AMPATTY
Member Posts: 3 ✭✭
Why does the following code throw a "Duplicate feature parameter 'tubeLength'" error when the definition.tubeLength definition can only execute once?
annotation { "Name" : "Type" } definition.tubeTypeTest is TubeTypes;
if(definition.tubeTypeTest == TubeTypes.TOP)
annotation { "Name" : "Length" }
isLength(definition.tubeLength, TOP_TUBE_LENGTH_BOUNDS);
else if(definition.tubeTypeTest == Tube.HEAD)
isLength(definition.tubeLength, HEAD_TUBE_LENGTH_BOUNDS);
More specifically, how do I use the same definition.myVar with different LengthBoundSpec definitions based on the earlier input?
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,245
This is a current limitation. You can work around it by using different parameters in the precondition and then doing:
if (definition.tubeTypeTest == Tube.HEAD)
definition.tubeLength = definition.headTubeLength;
in the body.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
in the body.
