holes to points in circular pattern
björn_britz
Member Posts: 14 EDU
i want to do holes. i created points in a circular pattern as the center for the holes.
no i have difficulties defining the locations and the scope in fs for the holes.
const anzahl = dimensions.Rotation;
for (var i = 0; i < anzahl; i += 1)
const t= rotationAround(rotationAxis, (2*PI* radian) * (i/anzahl) );
const point3d = t * patternPoint;
const point2d = vector(point3d[0],point3d[1]);
skPoint(PointSketch, "point" ~i, {
"position" : point2d
/* hole(context,"hole"~i, {
"style" : HoleStyle.SIMPLE,
"endStyle" : HoleEndStyle.BLIND,
"holeDiameter": 2*millimeter,
"holeDepth":3*millimeter,
"locations": XX,
"scope": XX
"locations": XX,
"scope": XX
heres the file: the problem starts in line 247
As described in the FS documentation:
Under the "Queries" section of https://cad.onshape.com/FsDoc/uispec.html
The `&&` operator in the body of a feature can only take booleans as its left and right hand side. "EntityType.BODY && BodyType.SOLID" would just be a syntax error because neither of those are booleans. The &&, ||, and ! operators are special cased for Query Parameter filters, but there is no special case within the code itself, and queries must be composed using the provided query functions.
