Multibody STL file
I have 2 parts in a Parts Studio that are not connected (they don't intersect) but are interlinked (like 2 links in a chain,) I want to export them as a single STL file so that I can 3D print the 2 interlinked parts. Any ideas are appreciated.
  • xphilipxphilip Member Posts: 17 PRO
    Just keeping the young ones on the straight and narrow - thank you Tim for all that you do here on the Forums :)
    Who's this "xphilip" pro-user-type-personage?  "x" as in ex-Onshape?  I hope not...
    @owen_sparks I think he was just logged into an alternate account :)
    That's no fun, I demand a conspiracy theory!
  • peter_molettierepeter_molettiere Member Posts: 1
    This thread is the closest thing I've found to the problem I'm having, but doesn't present an answer.  Hoping someone can help…
    I'm trying to export an assembly from OS to print with Xometry using Polyjet in multimaterial.  They require a single STL of the assembly with multiple bodies in order to print the different parts in different materials.  If I export the assembly as a single file, I get a single part in a single material.  If I export the assembly as multiple files, I get multiple parts.
    Can anyone offer any advice?
    Thanks in advance!
