UPDATING LINKED DOCUMENTS
papawo
Member, Developers Posts: 206 PRO
Can I update all the linked documents in one go in the feature browser, using featurescript or the normal way?
If you right mouse button on a tab you can update all references in one go for the whole tab. But you have to repeat this for all tabs. Please submit an improvement if you would like to update all tabs at once2
thanks!0
I would like this for drawings as well.raj_Onshape said:If you right mouse button on a tab you can update all references in one go for the whole tab. But you have to repeat this for all tabs. Please submit an improvement if you would like to update all tabs at once
1 -
You can also just click on the blue chain link and it'll update.0
Can I add a vote for this? I've a design with 20 or so parts and assemblies driven from properties in a feature script. If I change a single property, I have tp go through 20 tabs to update all the versions.
I'm only looking to apply a version to all related parts in a single project, not between projects.
Iain2
