Adding features to sheet metal flat pattern
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Could anyone please advise me how to bring up the update video on adding features to flat pattern in sheet metal please.
Been trying for a while now without success. It may have been included in a webinar which would also help.
Regards Brian
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 370
    What features are you trying to add? Right now you can place sketches on the flat pattern use the extrude feature.
    You click on 'Sketch' to create a new sketch, open up the flat pattern view and click on one the flat pattern. From there you can sketch profiles and use extrude to perform cuts.
    Twitter: @bradleysauln
  • Jake_RosenfeldJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,639
    ^ To add to this, once you've sketched on the flat pattern, extrude can perform cuts AND additions to the sheet metal model.
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Thank you, I have first drawn sketch , then gon to sheet metal, thickend it 2mm . Opened flat pattern, then opened new sketch on pattern and tried to
    extrude cut, or add hole but this does not seem to work. Could this be because I am using Safari browser, or am I making the wrong approach.
    Can you advise please Brian
    Accepted Answer
    Got it with your help Many thanks to all
