Convert Picture to sketch
How can I make a picture into a sketch to create a 3D model?
owen_sparks Member, Developers Posts: 2,660 PRO
Hi, and welcome.Upload picyre into document first.Then insert it into a sketchThen use the sketch tools to trace over the bits you wantThen use extrude or other 3d tools to turn it into a solid.If you have a document you're stuck on then feel free to link to it here and someone will jump in and help.Details about that here:- https://forum.onshape.com/discussion/9107/forum-post-checklisCheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
