icons like in hole feature?
adamohernadamohern Member, OS Professional Posts: 216 PRO
How are the icons added on the left of the hole feature length parameters? I don't see any mention of them in the std FS code.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,241
    That's not yet exposed to FeatureScript -- will come a bit later (probably with custom icons for your own features).
  • emerson_botteroemerson_bottero Member, Developers Posts: 37 ✭✭
    +1 @adamohern. I need it to.
    Hope we can use only the icon with no text either, only mouse tip  whem hover.
    Actually you can use exactly the icons of the Hole feature if your annotations are named exactly as in the Hole FS of the std document
    Like in this example:
    <div>FeatureScript 961;</div><div>import(path : "onshape/std/geometry.fs", version : "961.0");</div><div><br></div><div>annotation { "Feature Type Name" : "My Feature" }</div><div>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)</div><div>&nbsp; &nbsp; precondition</div><div>&nbsp; &nbsp; {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.holeDiameter, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.cBoreDiameter, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.cBoreDepth, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.cSinkDiameter, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.cSinkAngle, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.tapDrillDiameter, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.holeDepth, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.tappedDepth, LENGTH_BOUNDS);</div><div><br></div><div>&nbsp; &nbsp; &nbsp; &nbsp; annotation { "Name" : "My Length" }</div><div>&nbsp; &nbsp; &nbsp; &nbsp; isLength(definition.tapClearance, LENGTH_BOUNDS);&nbsp; &nbsp; &nbsp; &nbsp;</div><div>&nbsp; &nbsp; }</div><div>&nbsp; &nbsp; {</div><div>&nbsp; &nbsp; &nbsp; &nbsp; // Define the function's action</div><div>&nbsp; &nbsp; });</div>
    Un saludo,
    @ilya_baran Are there other icons we can use?
    Un saludo,
    I have just found 3 more
    <span>        annotation { "Name" : "My Length" }
            isLength(definition.dx, LENGTH_BOUNDS);
            isLength(definition.dy, LENGTH_BOUNDS);
            isLength(definition.dz, LENGTH_BOUNDS);</span><br>
    Un saludo,
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,062 ✭✭✭✭✭
    Does offsetX offsetY and offsetZ work?
    No
    Un saludo,
    I think you guys got all of them...  We plan on more customization in this area, but it's not the highest priority.
