Access the version name via a global variable or feature script
fredrik_tärnell
fredrik_tärnell Member Posts: 29 ✭✭
edited January 2019 in Community Support
Would like to make an embossed text on my part with the versionname for an highly iterative process 3d printing and making small adjustments in between.
I cannot tell the different versions apart by looking at the. Possible today already??
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
    This is not possible and we have no plans to make it possible: we don't want users to worry about geometry changes when you create or rename a version or copy a workspace.  You can use a local variable for this which you edit.
  • fredrik_tärnell
    edited January 2019
  • ilya_baran
  • ilya_baran
    The requests you link to are for using variable values in sketch text -- that is already possible with FS and we do have plans to enable this without using FS.
    The part of your request that is problematic is using a version name as a variable: a fundamental aspect of Onshape's design is that once you've created a version, you have nailed down the geometry (referencing, release management, caching, etc. all depend on this).  So there's no way a version rename could alter the geometry in that version.  What I can imagine happening at one point that would address your need is if we simplify the use of the API to the point where it's suitable for general individual use: then you could write a function that first modifies your part studio sketch text with the intended version name and then immediately creates a version with that name.
