FeatureScript with sketches
jrs_spedleyjrs_spedley Member Posts: 71 ✭✭
Can I just confirm that you can't access geometry in a sketch with featurescript?
I have a vertex selected from a sketch as a parameter and I'd like to query all the edges in a sketch connected to that vertex.  I've spent about 2 hours trying and I've come to the conclusion it isn't possible.
  • jrs_spedleyjrs_spedley Member Posts: 71 ✭✭
    Thanks for your help but I've now spent 45 minutes trying to figure out how find the sketch id of the sketch which contains the vertex I pass as a parameter.  Not sure what is wrong with "vertex.parent" or something like that :)
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    You can use https://cad.onshape.com/FsDoc/library.html#lastModifyingOperationId-Context-Query except you'll have to strip out the last part of the id -- so something like:
    var operationId = lastModifyingOperationId(context, myVertex);
    var featureId = resize(operationId, size(operationId) - 1) as Id;
