Rhino Failed Import
famadorian
Member Posts: 390 ✭✭✭
I tried to import a 3dm file and it failed. I authorized Onshape to take a look. Is there some way to follow this "take a look"?
I confirmed that the 3dm file worked in Rhino.
Can you restore your document so I can take a look (It says it is in the trash)
The only formats I found that were compatible were 3dm, stl and obj
STL is not an option for ArchiCAD and OBJ is only for mesh.
3dm succeeded in exporting surfaces and I loaded the file into Rhino and it worked there.
If you want to generate surfaces from an imported STL or OBJ, you can use 3d fit spline around the edges of the surface, then use fill surface
Other than that, can you export from rhino into something else?
Sure, I can convert the file in Rhino from 3dm to something else, but isn't 3dm the preferred format?
