Help with determining if a selected input is a sketch vertex or a mate connector please. - FIXED
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
I'm having a struggle to get a FS working and could use a hand if anyone's free to help.
Given the new implied mate connectors added in the last Onshape update it seemed a shame not to use them, so I'm trying to have a FS that's happy to accept sketch points or MC's
The precondition is fine and happy:-
annotation { "Name" : "Target Sketch Points or MC", "Filter" : EntityType.VERTEX && SketchObject.YES || BodyType.MATE_CONNECTOR }<br> definition.TargetsketchPoints is Query;Later we have a for loop to work through each selection in turn.
I'm using a transform which needs to be different depending on what was selected so am trying to test to determine if it's a vertex or a MC.
var TargetPoints = evaluateQuery(context, definition.TargetsketchPoints);<br> var TargetPointCount = size(TargetPoints);<br><br> debug(context, TargetPointCount ~ " TargetPoints");<br><br> var transform; //Needs setting as a transform and then initialising?<br><br> for (var i = 0; i < TargetPointCount; i += 1)<br> {<br> <br> //Evaluate Targetpoint to see if it's a sketch vertex or a mate connector so we can apply the correct transform method<br> <br> //If using a Mate Connector as an input<br> if (definition.TargetsketchPoints[i] == BodyType.MATE_CONNECTOR)<br> {<br> debug(context, "LoopCounter:- " ~ i);<br> debug(context, "is a Mate Connector");<br> <br> transform = toWorld(evMateConnector(context, {<br> "mateConnector" : TargetPoints[i] <br> }));<br> } <br> else //It must be a sketch point as an input<br> {<br> debug(context, "LoopCounter:- " ~ i);<br> debug(context, "is a Sketch Vertex");<br> <br> var skPlane = evOwnerSketchPlane(context, {<br> "entity" : TargetPoints[i]<br> });<br> <br> skPlane.origin = evVertexPoint(context, {<br> "vertex" : TargetPoints[i]<br> });<br> <br> // if (definition.isFlipped)<br> // {<br> // skPlane.normal *= -1;<br> // skPlane.x *= -1;<br> // }<br> <br> transform = toWorld(coordSystem(skPlane));<br> }<br><br> <br> const instantiator = newInstantiator(id + i + "instantiator");<br> <br> addInstance(instantiator, build, <br> {<br> "configuration" :<br> {<br> "BoltLength" : definition.LengthSelected,<br> },<br> <br> // "transform" : toWorld(coordSystem(skPlane))<br> "transform" : transform<br> });<br> <br> instantiate(context, instantiator);<br> <br> }<br> }<br>
(Question 1)
From the debug I can see the if statement isn't yielding what we're after. The total count is correct but only the "else" code is ever executed so my condition
if (definition.TargetsketchPoints[i] == BodyType.MATE_CONNECTOR)must be incorrect. Am I going about this completely wrong or have I just got the syntax wrong? Is a MC still a MC after it's put in the array or is it translated into something else?
(Question2)
I'm using a variable to store the transform. If set as a "transform type" it needs to be initialized. The snipped above doesn't set the type and instead initializes the variable (without type) within the loop. Is this acceptable? It seems to work OK, the transform executes fine. Should I instead initialize it to a do nothing transform; if so what's the syntax for that?
Sorry for newbie questions.
Cheers, Owen S.
For future reference, definition.TargetsketchPoints is a Query, not an array. So the real equivalent of "definition.TargetsketchPoints[i] == BodyType.MATE_CONNECTOR" would be
