universal coupling
chand_basha
Member Posts: 63 EDU
hi,
I designed a universal coupling every came good enough but the output shaft is revolving instead of rotating about its own axis.
someone help me out
here is the link
https://cad.onshape.com/documents/e5b7eab217a3012659cad55a/w/36556c2741fa813cfaeb654a/e/1dd8e90d759b2f35cdc60790
someone help me out
here is the link
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
@chand_basha - You will need to make that Document 'public' for others (myself included) to see it!
Philip Thomas - Onshape5
When all the constraints are applied, the mechanism isn't working as intended. Even though I have double checked it from all points of view. Kindly help me rectify it.
I need to share the file to students so that they can interactively watch the mechanism work on their mobiles.
Here is the link (I have made it public already)...
https://cad.onshape.com/documents/9f4b177ec255ce0352d5d12b/w/1cca9239a71dae6c0d26f4c2/e/b43a2ec92d2e2ebe524577e3
Regards.
You will need to mate the green bit so it won't slide.
You could probably use a mate connector between entities on the red parts
There is nothing wrong in your design, but the thing is you have to use two universal couplings for making input and output shafts to rotate in their true axis. And you can observe the same thing in Automobiles also.
Hope This will Help !.
Cheers,
chand.
Was intrigued and put something together. Maybe this will help:
https://cad.onshape.com/documents/c363338064ee15c193b392f5/w/1d3835a1cf1d86fc6377efcc/e/93d86caa41186a405178b5ca
I saw your design it is nice. But I have a doubt, There is no fixed reference part through which the shafts are rotating.
I have tried fixing this problem, I don't know how far I succeeded. Please check this design and let me know your opinion.
*Revolute 5, 6 belongs to shafts.
Thanks
