Import Points
fredrik_1
fredrik_1 Member Posts: 27 ✭✭✭
Hello, does anyone know: is there any way to import point data into an existing Part Studio?
I tried with STEP 214AutomotiveDesign which can hold point data, but no points came in.
Best regards,
Fredrik
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    Onshape, Inc.
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    ^ Since that discussion we have also introduced reference parameters, so that you do not need to hard code a reference to the csv file, but can actually reference the file by taking it in as a parameter in the feature dialog. See this documentation (and scroll down a bit to CSV section): https://cad.onshape.com/FsDoc/imports.html#reference-parameters
  • Jake_Rosenfeld
    @fredrik_1
    FYI, If you go and look at that thread that Tim mentions, I have updated that custom feature with our new reference parameter workflow.  That feature should be all up-to-date on current FeatureScript best practices, and may actually do exactly what you need without any coding on your part.
  • Krz
    Krz Member, Developers Posts: 68 ✭✭✭
    You cannot import points as Onshape has no object like 3D point.
    You can import lines. For example 2 intersecting lines at the point.
    G
    M
    T
    Y
    EnglishPolishSwedish
    Text-to-speech function is limited to 200 characters
  • fredrik_1
    Thanks Krz
    I see that it might be possible through FeatureScript. All I'm trying to do is to import a lot of points, from a csv file or something like that so i can make various holes for screws. Anyone tried that?
    Best regards, Fredrik
  • TimRice
    Onshape, Inc.
  • Jake_Rosenfeld
  • fredrik_1
    edited May 2019
    Thanks! Guess i have to learn some basic Featurescripting :)
    As always great support from OS, Featurescript is so nice!
  • Jake_Rosenfeld
    @fredrik_1
  • fredrik_1
    Yes it works perfectly, to get the points in. I will now need the points into a sketch, to make the holes t? Will to figure it out my self..
