Python API: 401 Unauthorised when include_mate_connectors set to true in get_assembly_def arguments
anthony_cheunganthony_cheung Member Posts: 6
edited May 2019 in General
https://github.com/onshape-public/python-client/blob/master/docs/AssembliesApi.md#get_assembly_definition
^ I've been using the above code to get the assembly definition but when I set include_mate_connectors in get_assembly_definition call I get a 401 error.
However it works fine if I remove them.
Wondering if anyone could help diagnose this issue. Thanks.
  • Ethan_KEthan_K Member, Onshape Employees Posts: 57
    Thank you for trying out the experimental python client! I'm happy to help you here, but FYI, I posted an issue against the repo itself to track this issue here: https://github.com/onshape-public/python-client/issues/4
    edited May 2019
    Just fixed this -- see here: https://github.com/onshape-public/onshape-clients/blob/master/python/test/test_assemblies_api.py One thing to note is that the inlcude_mate_connectors only actually does everything if you also set the include_features flag.
  • anthony_cheunganthony_cheung Member Posts: 6
    Apologies I was inaccurate. It was actually if you put in any kwargs. Thanks for the quick fix!
    edited May 2019
    @ethan_keller769
    installed onshape-client with pip install (confirmed on 0.0.24)
    cloned the onshape-clients repo
    pipenv shell in onshape-clients/python then ran my get assembly definition code
    and now I'm getting Error 111 Connection Refused.
    tried without pipenv --> same error
    Let me know if I did something wrong, thanks.
    edited May 2019
    Hmm... what did you plugin for your baseurl in your credentials file? It should be https://cad.onshape.com (without the /api). Specifically, your creds file should look like (of course with your own credentials plugged in):
    prod:
    base_url: "https://cad.onshape.com"
    secret_key: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    access_key: XXXXXXXXXXXXXX default_stack: prod
    edited May 2019
    In my code I added the second line:
    configuration = onshape_client.Configuration()
    configuration.host = "http://cad.onshape.com"<br>
    Fixes the issue 111 error because the URL is correct now. Default configuration.host is set to localhost in configuration.py.
    However, now I get a returned None from my API call. Any ideas?
    I copied the URL the program uses and it works in my browser.
    That is because some of our APIs still don't have typing information migrated to openAPI. You'll need to add the keyword argument
    _preload_content=false
    @ethan_keller769 thanks for all the help
