Variable WORLD_ORIGIN not found Variable Z_DIRECTION not found
Fda
Fda Member Posts: 42 ✭✭
Why is the code broken?
I do not get it
const lineToRotateAround = line(WORLD_ORIGIN, Z_DIRECTION);  //?????????
                const angleIncrement = (360 * degree) / MyCount;
                var transforms = [];
                var instanceNames = [];
                //definition.count -> MyCount
                for (var i = 1; i < MyCount; i += 1) // Iterar de 1 -> (definition.count - 1) porque ya hemos creado la instancia base (0)
                    const currAngle = i * angleIncrement;
                    const currTransform = rotationAround(lineToRotateAround, i * angleIncrement);
                    // Añadir currTransform a la lista de transformaciones
                    transforms = append(transforms, currTransform);
                    // los nombres de instancia no importan, solo deben ser cadenas únicas
                    instanceNames = append(instanceNames, toString(i));
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,120 image
    Where are those variables declared? If they are standard Onshape constants did you include the module they are declared in?
  • Jake_Rosenfeld
    Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646 image
    @fermin_fermin_1
    These are fairly new constants in the system, your feature studio may be on too old of a version to have them.   Can you post a screenshot of the very top of your feature?  I am interested in the line that says "FeatureScript ####;" and all the imports that come after that.
    If you have an import of "onshape/std/geometry.fs" and the FS version is high enough, those constants should exist.
  • Fda
    @fermin_fermin_1
    </code>FeatureScript 1096;
    <pre class="CodeBlock"><code>import(path : "onshape/std/geometry.fs", version : "1096.0");
    This fixes the error:
    <div>FeatureScript 1120;</div><div>import(path : "onshape/std/geometry.fs", version : "1120.0");&nbsp;</div>
  • Jake_Rosenfeld
    For anyone with the same problem, `Z_DIRECTION` is just shorthand for `vector(0, 0, 1)` and `WORLD_ORIGIN` is just shorthand for `vector(0, 0, 0) * meter`
  • Fda
    So that no one else wastes time, as I did.
    const lineToRotateAround = line(vector(0, 0, 0) * meter, vector(0, 0, 1)); </code>const lineToRotateAround = line(WORLD_ORIGIN, Z_DIRECTION);  <span>//?????????
    </span><pre class="CodeBlock"><code>
