[BEGINNER] How to create a 45 degree sweep on a windmill fan (curved)
tobey_luke
Member Posts: 2 ✭
I am a complete newbie to Onshape and am wondering how to make a 45 degree curved sweep on my windmill fans, https://cad.onshape.com/documents/b4b56fd1eed564bcc4a526ec/w/9e3ff1f4c6feddc0343ba012/e/037a6d0b70cb6e1d3a0e06c9
Anyhelp would be apreciated
Thanks
Tobey
Thanks
Tobey
Hi and welcome.Sorry, that's a bit of a vague question. Can you do us a back of napkin sketch to give us more to go on? When you say "sweep" do you mean a twist to the blade? "Sweep" is a "feature" in Onshape that could be used here so the word may be confusing things...Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@tobey_luke
Like Owen says — we could do with a bit more description
But if you’re looking for something like a fan blade then take a look at the link below. And be sure to rotate around the part. Realize that this is just a basic fan blade
Step through the features list to see how it was done
https://cad.onshape.com/documents/4946195b2ebfe68ab5b8046e/w/f3d9c3b64ddd13895b9f953a/e/88a08f99fd7a3b754272fc4c
To attain the twist that I think is what you are after, I use a feature script called tangent plane to create a plane on the surface of the cylinder. I then made a new sketch of a small rectangle. I the created another offset plane from the tangent plane and made a longer rectangle. I used TRANSFORM to rotate the longer rectangle 45 degrees. I used the loft tool to create the blade. I used MOVE FACE to ensure that the start of the blade fully intersected the hub. On the right plane I made a new sketch to create an axis to use in the circular pattern tool. - Scotty1
@tobey_luke
Welcome to Onshape and the friendliest forum in the universe!
A couple of methods have been posted and you should be able to learn a lot going through them. Not to confuse - I modified your approach and made a possible blade. Note it is good practice to keep your sketches simple and then use the various part or feature pattern tools. That not only makes for quicker documents it is easier once you have the knack.
https://cad.onshape.com/documents/4d3d1920bfe80dfaeb8bfd87/w/50e08dde6b03e0ee72a50e9c/e/8aeab9175e4f67ce55c67898
www.accuratepattern.com1
